Pro Lightning K1, K2 or K3?
Car: 88 IROC-Z
Transmission: 700-R4
K1: with Hydraulic springs, 1.460" Single w/dampner, 110#@1.800" to .550
K2: with Mechanical springs, 1.460" Dual w/dampner, 135#@1.800" to .600
K3: with Roller springs, 1.540" Dual w/dampner, 190#@1.900" to .660
I don’t wanna go with the K1 because it has single springs. So can I use any of the K2 or the K3? Cam is going to be the LT4 Hot Cam and when If I go with 383 kit im planning to swap it with Com 224/230 so the lift with the 1.6 rockers will be .544
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I dont know your answer, get the closest to what your cam manufactuer recomends.
I would never rely on springs that came on a new set of heads. Always buy the springs made for your cam. If you get a new cam, buy the correct springs.
Car: 1991 Firebird
Engine: 383 stroker
Originally posted by 305sbc
K2
K2
Car: 88 IROC-Z
I already have the HOT CAM and planning on the CC 224/230 in the future, some say the K3 is an overkill and will kill my lifters
1 Post
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
the k3 kit would be the max for hydraulic lifters and theres no reason to push them if you don't have to. A hot cam in a 350 or xe 274hr in a 383 isn't going to rev much past 6000 so you shouldn't need any bigger springs than whats in the k2 kit. The k2 is what I'm planning on buying in a week or two.
As for replacing springs or buying bare heads they should work fine, but I would never try to run them at the limit, such as with .590 lift on their .600 max lift springs.
Car: 88 IROC-Z
It says K2 comes with Mechanical springs, what are Mechanical springs? And can I use them with a Hydraulic cam? If so I’ll get it with the K2.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Mechanical refers to the type of lifter not the spring itself. I would go with the k2 kit for anything hydraulic!
