350 heads
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If they aren't already, port them ( http://www.sa-motorsports.com/diyport.htm ).
Unshroud the valves a little more, which will increase chamber size a bit. Use a thick composition gasket, and compression will stay in control.
By all means, DO NOT use domed pistons. Flat tops with valve reliefs at most. Even mild dished would be okay (don't need to increase chamber size or use thick gaskets if you go with dished pistons).
I haven't done it, but I've been thinking/researching a 350 shortblock using the rest of my package for some time.
theshackle
03-05-2017 06:37 PM
NinjaNife
08-23-2015 11:49 AM
