GM LT4 HOT CAM and Stealth Ram
Car: 89 Firebird Formula 350 WS6
Wanted to know if anyone has run the Holley Stealth Ram setup with a GM LT4 Hot Cam? Or what are some opinions on the setup? I'm running Trick Flow Twisted Wedge G2 Heads and headers. Any other ?'s, just ask.
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
What were you looking to know? It is normally good for mid 12s @ 108ish with the right drivetrain and tune. I can't vouch for that yet because of my lack of WOT tune, not-so 2400 stall, and slipping stock 700r4. I can, however, vouch for driveability. The setup will need normal VE tuning, increased idle speed, accel enrich tweaking(more than a normal LTR /w cam), and increased TC lockup speeds depending on gear. My setup runs 13.2x@105 and would be a good daily driver if it wern't for the low teen city gas mileage.
so are you running just the GM LT4 Hot Cam or the cam AND Stealth Ram? Any other opinons or examples are welcome
:lala: :lala: :lala: :lala: :lala:
9192camaro
16
02-03-2019 12:21 AM
L98GTA87
08-11-2015 06:55 PM
