Solid Roller Question
A couple of questions:
What all needs changed besides the cam and lifters to convert to solid roller? Also, I'm assuming the valve springs need more seat pressue right? I currently have 1.46" double springs and was wondering if they'll work. Thanks.
Converting to solid roller requires: the cam, solid roller lifters, springs to match the cam, cam button and of course lashing the valves. While your springs will work, you might not see the full power that a solid roller cam can provide.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I gotta little question for yas... Do solid rollers require a break-in? Like how hydraulic rollers you don't need to break 'em in...
junkcltr
08-02-2019 11:12 PM
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
