Lightest third gen?
Car: Check The Sig
Lightest third gen?
What is the lightest third gen? Someone just told me that in 82, the base firebird was 2800lbs? I didnt know that you could have the car weigh that little?
Car: 98 T/A
Engine: ls1
base firebird with the LQ9 L4 might've been the lightest
I would stick with the V8 power though
89 formula may be one of the lightest V8 fbodys
got no reliable data though
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
The 82's are the lightest F-bodies ever made. You could get them close to 2800 #'s with a four cylinder and a little less then 3000#'s for a 305 V8.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My 88 formula 305TPI A4 with full interior, spare tire and jack, 1/4 tank of gas, t-tops, power locks and windows, and Ram Air II hood weighed in at 3400lbs even with no driver.
Car: 1989 C4
Axle/Gears: 307
Sports car my ***.
See thats just plain sad. My 76 short box with a SBC weighs in at 3000 with 3 gallons of gas add me 230 and its still lighter then most 3rgens. I would really estimate my 82 would be around 3300 without driver, guess its time to hit the scale.
1 Post
Car: '82 Z28
Engine: 350HO
Transmission: M4
2875/3169 (std/Z28) for the '82 model year.
pretty light.
thats with an automatic transmission.
figure with the 4-speed saginaw, which is only about 80lbs.
and no a/c, or emissions equipment.
probably right around 3,000lbs for a Z28.
pretty light.
Hotrodboba400
12-10-2019 07:07 PM
