How much does the cooling system hold??
How much does the cooling system hold?? I need to drain all the coolant out and I was wondering how much fluid is in there.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: LT4 Hot Cam, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Fully Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 87 IROC
Engine: LB9 for the moment
apprx 4 gal... get two gal of coolant start w/ one coolant and one water... top of from there using 50/50 mix...
zroc
zroc
Hotrodboba400
12-10-2019 07:07 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
