Comp Xtreme Energy cams
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was flipping through my Comp Cams catalog. They say most of their cams are ground 4 degrees advanced but there's very little mentioned about the Xtreme Energy cams. Are these cams ground advanced also or straight up?
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: 4
Engine: 6
Transmission: 5
They're mostly set up with the intake lobe centered at 106º. I'm not sure whether you'd consider that advanced or not; I think these days you probably would, since the factory changed theirs by way of the timing set sometime around 1970 to 4° retarded from where they used to be, for emissions purposes, and have retained that to this day. Most of Comp's performance grinds are with the inake at 106°; their factory repro grinds are at 108° or 110°.
Are you looking for suggestions as to where one might best be installed?
[This message has been edited by RB83L69 (edited January 13, 2001).]
Stephen,
My year-old Comp Xtreme is ground with a 4° advance over the stock LT1 pattern. From that, you might presume that many of them are, but call Comp to find out for sure, or go to theire site and pull a cam card.
Later,
Vader
"I cannot take this any more... Saying everything I've said before..."
Adobe Acrobat Reader 4.0
Later,
Vader
Car: 87 IROC L98
I'll take your word for it. The catalog mentions that the High Energy, Pure Energy, Dual Energy and Magnum cams are ground 4 degrees advance. However very little is mentioned on the Xtreme Energy cam. I could only assume it is also ground advanced. I installed mine straight up. My timing set allows for an additional 2 degrees.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I've got an Xtreme Energy cam, and the docs for it mention that it too is ground 4 degrees advanced.
Car: 4
Engine: 6
Transmission: 5
IIRC the Magnum, High-Energy, and all those are also ground with a 106° intake center; so the XE series are the same as the rest of those.
Which one are you considering?
Car: 87 IROC L98
I've already considered and installed my cam in my big block. I went with the XE294H-10. I was just curious if it was ground advanced or not. The cam card quotes the timing specs for a cam installed at 106 intake center line however I never degreed my cam on installation to know if the valve timing on the cam card is considered straight up or 4 degrees advanced.
Car: 4
Engine: 6
Transmission: 5
Nice consideration!! IMHO that is probably the best thing to do in any case, then tune it from there if it seems necessary.
Hotrodboba400
12-10-2019 07:07 PM
