Cooling Problem, need some help.....
Old 01-12-2001 | 01:55 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Tonight as I got to my destination I noticed some smoke coming from the engine and the distinct smell of anti-freeze.
I looked under the hood but it was too dark to see very clearly.
When I got home I looked again. I noticed some coolant on the side of the engine bay down below the coolant resevoir. There were no visible leaks from any of the hoses.
I felt the hose going from the radiator to the top of the intake and it was very warm, it would burn your hand if you left it there for more than a few seconds.
I then proceeded to check the radiator cap, it was not hot at all, just slightly warm.
Thermostat that I just put on Sunday is a 195 degree stat, it was my old one, I took the 160 off due to cold weather and the interior was too cold.
The temp gauge in the car reads 200 degrees since the swap with the 195. I get a good amount of heat inside the car now.
I also changed my heater core on Saturday.
I have no idea what I should check to find out what the problem might be.
Thanks Guys.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old 01-12-2001 | 09:30 AM
Enkil's Avatar
I've got a crack in my reserve tank that sometimes lets antifreeze vapor come out of it for a few seconds.
I really need to get that fixed. heh
89 iroc-z 305 tbi
everything stock, except for a mirror that fell off
Old 01-12-2001 | 02:36 PM
84FTA's Avatar
The over flow connection that goes to the radiator broke off of mine. I didn't even put it back on because I don't use it in the winter. Did you overheat or did you just lose antifreeze? If you overheated it should come out of the top of the resiviour once it hits the selected pressure of the res. cap it will begin spewing out. The upperhose should be 195* if the theromostat has been open and you have been driving the car because if the theromostat doesn't open until 195* then all coolant going through the upper radiator hose has to be atleast 195* The radiator cap is different, it has cooled some by the time it reaches the radiator plus there is no direct coolant touching the top of the cap (the part that blocks off the coolant from going to the resiviour is what gets heated).
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
13.98 @ 101
Old 01-12-2001 | 10:20 PM
Zepher's Avatar
Well, I bought a new thermostat today and everything seems fine now. The one I put in on sunday was my old one, which I guess doesn't work right. Temp is now at about 160* since it's cold outside.
chazman
08-28-2018 03:25 PM
greenyone
09-02-2015 03:39 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
masonta
09-01-2015 06:40 PM
Quick Reply: Cooling Problem, need some help.....
