1 piece rear seal or 2 piece rear seal??
whats the diff between a 1 piece and 2 piece rear seal? if i have an engine with a 1 piece rear seal can i put in a 2 pc rear seal rotating assembly? what is a rear seal?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The rear seal holds the engine oil inside the engine around the rotating crankshaft. It's located right behind the rear main bearing.
You can put a 2-piece rear main rotating assembly in a 1-piece block by use of an adapter. Costs $100, last time I looked.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by 88tbi4x4
Can you put a 1pc seal crank into a 2pc seal block?
Car: 83Z28 HO
Transmission: G Force 5 speed
Just my opinion, but who cares??? Yes- a 1 piece seal is an improvement over a 2 piece, but remember - they ran 2 piece seals since.....well for a long time.
Engine: LS1/LQ4
Only those who don't like leaks care.
I've had many, many 2-piece seal engines. Most were used (only one new), some rebuilt, but they all leaked to some extent. The "new" one is a Goodwrench 350 I have in my van now. It's the best I've had, have 60k on it now, but even it weeps more than my 160k LG4 seal.
Car: 4
Engine: 6
Transmission: 5
It's really not hard at all to get a 2-piece to seal. I never noticed it being a problem with factory motors, until they hit about 10,000 miles, and all of the gaskets and seals started turning to dust just from age and heat and all.
The main reason the factory changed the design was not because the old kind leaked; it was to reduce assembly time. Anybody who builds motors can tell you that it takes a while to put in a 2-piece one; probably 5 or 6 times as long as it takes to bonk a 1-piece one into the carrier and bolt it up.
Car: 83Z28 HO
It's not difficult if you're doing the install yourself to get a good seal with a 2-piece. I never knew they changed over due to assembly time.
5-7 : Yes, I'm also one of those guys that don't like leaks.
In the 6 or so engines I've rebuilt, only had a problem with one weeping.
Oh - and I actually use the rubber china wall gaskets on my intake too.....without leaks!!
But - no argument....a one piece seal is less likely to leak over time. On the other hand, I'm not going to ditch an engine because it has a 2 piece crank seal...
Car: 4
Engine: 6
Transmission: 5
so which would be best 1 pc or 2 pc?
The seal by itself doesn't really matter.
2-piece stuff (flywheels, etc.) is easier to find. But, no 2-piece blocks are equipped with the factory roller setup, so if you get a factory roller block which is cheaper to roller-ize, it will be 1-piece. However not all 1-piece blocks are roller-ready.
Other than that, it makes little difference.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
