Nick in head mounting surface, what to do??
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I got a new bare set of corvette heads from the classifieds. When i got them I was disappointed to find a nick in the heads surface where the head meets the head gasket. Below is a picture, is this head now unusable?
Use a bodymans metal file or a flat file to file off any high spot or raised metal. lay the head gasket on the head and see if the nick is under the fire ring of the gasket.
It will likely seal up fine.
1 Post
Car: 1989 Iroc-Z
Car: 4
Engine: 6
Transmission: 5
Yup, just file it down gently and carefully, and see where it ends up.
Happens all the time with aluminum parts. It's very easy to do, because of how soft aluminum is.
Lay a head gasket on it and see if it's under the fire ring. If it is, either have it welded and ground back down, or try some epoxy (which may not work if it protrudes into the cylinder).
Originally posted by 89 Iroc Z
It is right under the fire ring, will this be a problem?
Test the motor for compression before starting it.
I wouldn't loose sleep over it.
It can be repaired if it leaks. (Milling, aluminum welding)
Probabily a non-issue thou.
1 Post
Car: 1989 Iroc-Z
I got UPS to pay for the damage... The machine shop said the head will need to be milled.
My question is if I mill one head don't I need to mill the other to keep the engine equal? The machine shop guys said it won't matter because not that much is being taken off.
If UPS is paying, do both heads the same. I won't be "that much" $more$.
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
ambainb
04-25-2016 09:21 PM
hectre13
09-08-2015 03:38 PM
