383 Questions
1 Post
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
383 Questions
Okay... I am beginning to plan out building up a 383 to replace my 305 TPI, I will be porting my base and adding aftermarket Runners, maybe an aftermarket Throttle Body also.
Anyways, I think I understand the majority of the 383 correctly, but please correct me if I am wrong.
A 383 is a 350 Block taken .030 over, with a 400 Crank which has either had the mains ground down, or the block has had the main enlarged... correct?
I've seen 383 rotating assemblies with both 5.7" and 6" rods, so either can be used, with the correct pistons right? What would be the benefits of using 6" rods over 5.7" rods? I hear H-Beam rods are a better choice for 383's as they usually have enough clearence, although they are heavier.. which rods would be better, I Beam or H Beam... or would I want to find some LT1 rods?
Now for my main question... are 383 Pistons just plain .030 over 350 Pistons, or are they special?
I was thinking of finding a 350 block, and taking it .040 over, then getting pistons that were .040 over and continuing to build it like a 383... but I got confused about the pistons.
Thanks Guys!
Thanks Guys!
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The 400 crank mains have been ground down to 350 size.
The location of the wrist pin has to be correct for the stroke and length of rod. 6" rods reduce the side loading on the pistons, and there are other differences they make with regard to the piston motion.
You need special 383 pistons whether you use 5.7" or 6.0" rods. I beam will be fine for a street 383. .040" over pistons are available for 3.75" stroke.
Don't forget block oil pan rail clearancing, external balancing.
1 Post
I guess I beam rods are where I was going anyways.. 6" would be better for higher rpms or not?
So lemme get this correct about the pistons.. all 3.75" stroke pistons will work? or do they need to be designed specifically for a 383 engine?
1 Post
Originally posted by xpndbl3
3.75 stroke is an 383 piston.....
you mean 4.030 bore piston made for a 383 not 3.75 BORE piston
Thanks guys!
Car: 82 Z-28
Engine: 383 TPI
If you go with I-beams, you may have to grind the heads on the rod bolts. All depends on the cam.
In my case, I had to replace the I-beams with H-beams to clear my cam (LPE 74211).
If you buy a pre-balanced stroker kit with I-beams, and you have to grind the rod bolts, it will need to be re-balanced.
383 pistons are special, no matter if 5.7" or 6" rods are used.
The performance difference between rod lengths is more thoeritical than practical, but yes, the 6" is better for higher RPMs.
Also, when I was still planning on running I-beams, I had to grind a little on the bottom lip of the cyl walls for clearance.
BTW: The generally accepted min clearance for rotating assy-to-block-to-cam is .050", but some report suscess with less.
1 Post
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
There are now 5.7 I beam rods with cap screws on the market. Should help with the clearence problems. If this engine is mostly a street then go with the 5.7 rods, as the wrist pin goes right through the oil ring for the 6". They do have some steel rings that go below the oil ring for support, but I still wouldn't use them for a street engine. Just my 02. There are some kits out there offering cast cranks and forged pistons and rods already balanced, for up to 600 lift cams. I'm running a 600 lift cam in my 383, had to cut .080 off of the rods to clear, and that is a small base circle cam.
1 Post
Ok, It's starting to sound better again... 5.7" rods with cap screws... sounds nice... I'm not looking for a cam with that much lift, although it's close, the one cam i am looking at (LPE 74211) has 560 lift (with 1.6 rockers) on the exhaust side. If I don't go with that cam, It would still be something along the same lines. with Probably around 550 life on 1.6 rockers.
Think the majority of 383 rotating assemblies would clear that?
Car: 82 Z-28
Engine: 383 TPI
If the rotating assy came with Eagle H-beams, then yes it should clear without grinding on the rods.
I don't have any experience with the cap-screw type I-beams, so I can't comment on that.
I was using 5.7" stock style I-beam rods when I ran into cam clearance problems. I switched to Eagle ESP 5.7" H-beams, (which use cap screws), and they cleared my LPE cam with room to spare. Dirttrackthunder.com was selling them cheaper than everyone else I found.
Something else to consider, if you go with pressed fit wrist pin type rods (like stock rods) then switch to Eagle H-beams, you will need a different type of piston. A floating pin type piston. Then you get to re-balance it all over again.
Learned that one the hard way..
I tried the cheapest stroker kit route (enginekits.com I.E. Powerhouse) first. Wound up only using the crank from that kit.
If I had it to do all over again, I would just buy an Eagle rotating assy with the H-beams.
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Get on ebay, type in 383 crank. There are kits on there for 800.00 with the cap screw sir rods, already balanced and clearenced for 600 lift cams. Come with balancer and flexplate too. Eagle rotating assys.
1 Post
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Originally posted by TheMysticWizard
My thoughts exactly... although I thought about buying stuff seperately, as it might be a little cheaper, but balancing would probably drive it right back up.
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Do not get the new Eagle I beams with the cap-screws. I went through 2 sets and both were out of round. Eagle said their may be a recall on this. The rods are not torque properly when getting align. I ended up sending my rods back and getting H beams. My machine shop has also seen these eagle I beams poorly made.
Mickeyruder
09-02-2015 02:45 PM
gixxer92
09-01-2015 04:32 PM
