I get shocked when I grab my distributor
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
89 TBI remote coil ignition
a year and a half ago I installed a new copper cap/rotor. Last winter I began having electrical probs such as a delay in my lights turning on, erratic wipers, and humming speakers. I let these probs go since it's got 223k miles. Last week I went to adjust my timing and my distributor zapped me. It seems like it does it whenever I grab the top of it, and it's got quite a bit of voltage. I replaced the cap/rotor and that made no difference, still shocks me. While I had the wires off I did a visual and they are old but are not cracked and seem to be in good condition. My assumption is that the random elec. probs. and me getting shocked is being caused by a wire searching for the nearest ground, but does anyone know where to look next?
yeah, I've already bought wires for it, I'm just lazy and I don't have time to cut and crimp them (I like to route them neatly). I'd like to be sure of whatever it is that's causing me to get shocked, because if it might be something else, I'd much rather use the new wires on something else. I'm aware that wires are to blame for the humming, summit did an article on it. But I've never been zapped when setting my timing before, and like I said, up at the cap the wires look to be in good shape. Just wondering if it might be something else, like a lead to the coil? I do have a braided fuel hose that touches the plastic side of the coil, thats how gm routes it though so that doesn't concern me.
well, id start off by not touching the wires....lol....then maybe replace the wires, boots on the wires are prolly dry rotted all to hell causing poor insulation.....while you are at it, now is a good time for plugs, dist cap, rotor, coil.......change the oil...ect ect
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
Originally posted by CEP89
I have been shocked by touching old cheap plug wires while adjusting the timing. After putting on new thick wires from MSD it never happens.
i have a BRAND NEW full MSD ignition (box, coil, distributor wires) and i get shocked every now n then...you wont get shocked if u grab the distributor by the cap., not the top were the wires are..And remember those little shocks your getting arent very strong..kinda compared the the strength of scrubbing your feet on the carpet and then touching metal...The human body CANNOT take 40-50,000 volts (without some sort of damage)...
I got a zap from sticking a test light through the rubber terminal on top of the distributor to "kill" that cylinder and the entire spark voltage went into me...that literally knocked me on my @ss..
those little "shocks" are gonna happen...just try not to absorb an entire fully charged spark..thatll hurt, for a while i might add
if you are using a solid care wire then there is were your humming is coming from...get a good wire, NOT a solid supression
wire..
the ground your talking about is you..you are the closest easiest to travel through ground ESPECIALLY when your touching the distributor...try this and youll see what i mean...touch your tire when u grab the wires/distributor....when i have to touch my DIST. i try my damndest to grab it by the cap
I know it's using me as a ground when I touch the source, I was just trying to narrow it down to where it might be coming from before I go and change my wires if I don't need to. And the strength of the shock- it's significant, to say the least. I felt it on my hand and at my foot when it went through my shoe to the ground. And yes, my hand felt funny for a while after that. Kinda the same as when you pull the bare spark plug wire off an 8 horse rototiller when your dad thinks it would be funny to tell you to do it because you are only 10 years old and you don't know any better and.........
Car: 4
Engine: 6
Transmission: 5
Next thing is, it shouldn't be doing that. You probably need a dist cap, and/or wires. The spark energy should be staying where it is put; namely inside the cap and inside the wires, not jumping out and grabbing your bad self. Something with insulation isn't insulating as well as it's supposed to be doing.
ok, so I gather the consensus is that spark plug wires (and coil to dist. wire) are the only ones that can pack a punch like that. I was just making sure. Since I just replaced the cap I guess all signs point to the spark plug wires. Oh well, I'll change them with my 8mm's hopefully this weekend and write a followup. Thanks
Car: 84 Z28 Camaro
Engine: 350ci
Mine does the same thing. I have a slightly older cap and new
Taylor wires so I suspect the cap in my case. It really hurts
with a hi-voltage coil !!
i know its hard to tell but...is the spark jumping trhough the plug boot , or the cap itself.....and...is it jumping from a certain area?? maybe one of your cap terminals is cooroded and it isnt making a good full contanct and seeking a place to jump to i.e. your HAND... lol
i still say just replace the cap and rotor.....its normal routine stuff anyways.....
1 Post
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
Well I'd say it's the plug wires, since it's the same with the new cap/rotor.
RedLeader289
05-28-2019 01:47 PM
LT1Formula
10-08-2015 08:34 PM
Damon
09-26-2015 04:29 PM
