Serpentine belt for smog pump removal.
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the 970k6 will work just fine. i'm using that same belt on a 92Z with AP delete.
the 970k6 @ autozone one will work for fine for the price of $16.
Car: 2002 Formula Firebird
Transmission: 4l60e
I'm running a cheapo belt from advance. I think I paid 10$ for it after my employee discount. I'm running a different setup though. I did a AC and smog pump delete...and a passenger side bracket delete
I'm running a 50'' belt now.
Car: 1990 Formula
Axle/Gears: 3:73 Posi
pics 88Camaro? i am trying to remove as much useless under hood clutter as possible (already removed all a/c and all smog equip) i also replaced both the overflow and washer fluid bottles with a single unit out of a 91 ford explorer and put it where my charcoal canister was.
the belt i am using for the smog pump delete is a 935k6
but i am guessing the crank pully on this motor is different than a stock thirdgen. i got the motor from a 89 corvette.
Transmission: 4l60e
I'll try to get some pictures. I hacked up some old style alternator bracket to make mine adjustable. It works really well actually. I will try to get some pictures up soon.
1992 Trans Am
05-10-2023 07:19 PM
evilstuie
01-09-2020 08:29 PM
mustangdmurder
08-21-2015 07:17 PM
