Is there a way to disable the check engine light?
Car: 1989 Iroc-z 1994 Z28 LT1
Engine: 5.7 Liter L98 Tuned Port Injection 5.7 LT1
Transmission: 700R4 and 4L60E
I was wondering if any body could tell me how i could disable the check engine light from coming on????? I have fixed everything on my car and it just stays on so I just want to know if there is way to get it to stay off permanently???
Car: 1985 IROC-Z
Engine: 5.0L TPI
Transmission: TH700R4
If you really want to you can just remove the bulb in the dash. But the better question if to find out if there is any codes stored in the computer.
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Yea I would recommend checking the codes, for info on how go here: https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Car: 1985 Iroc-z
Engine: 355 sbc
have u reset the ecm? sometimes it will still flash, even if the problem was fixxed...
you should reset it everytime u pull codes and u think u fixxed them...
(disconnect + cable for 15 or so mins..)
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
no offense
that sounds like something my mother would do
no she covers it with a sticky note
1 Post
Car: 89' IROCZ
Engine: 5.7 L98
My car had a piece of cardboard covered in black electrical tape at the front of the shaft( to keep the light from burning it I guess). I wouldn't do this, your car is telling you something you need to know. There are tech articles on this site on how to find out why it's on. Once you have fixed the problem all you need to do to turn the light off is to disconect the battery neg. terminal for 15 min. and reconnect it. What code did you get and what did you do to fix it? Mine goes on sometimes for the MAF and it's because the electrical connector is beat up. All I have to do is disconect the MAF and reconect it, and then clear the code. Your car will run better if all it's sensors are working.
