How wide is a 1970 Chevelle's wheelbase?
Old 12-27-2000 | 08:02 PM
Trevor's Avatar
I've looked everywhere, can anyone help? Also, how long is a BBC, like a 454? Thanks
Old 12-27-2000 | 10:24 PM
Vader's Avatar
Trevor,
Wheelbase is the center distance of the front axle to the rear axle. Track is the center distance from one side of the vehicle to the other, and the front and rear track widths are usually different. By your phrasing of the question, I'm not sure what you are asking for. Care to re-state?
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old 12-27-2000 | 10:31 PM
Vader's Avatar
BTW -
To my recollection, the wheelbase of a '70 Chevelle should be 110", the front track (with zero offset wheels) should be 59", the rear track should be 60". Those are from recollection, so feel free to correct me where I might be wrong (as always).
I do know that a BBC MkIV is 31½" from the front of the water pump shaft to the rear face of the flywheel. The bare cylinder case itself is 24-7/8" long without a timing set, crank, covers, etc.
Later,
Vader
BrianChevy
Wheels and Tires
08-08-2019 03:16 PM
Bubbajones_ya
10-25-2015 09:01 PM
PAFORM350
Wheels and Tires
10-02-2015 08:21 PM
Vincent135
09-28-2015 11:50 PM
Abubaca
Car Audio
09-24-2015 03:33 AM
Quick Reply: How wide is a 1970 Chevelle's wheelbase?
