old lifters with new cam?
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
hi,
i would like to know, if i can reuse my old lifters with a new camshaft? and how much hp/rpm is the max with the stock lifters, if there is any limit
engine is a 91 L03.
Nebu.
engine is a 91 L03.
Nebu.
Car: 91' Camaro
Engine: Carbed 305
yes, theyre rollers. i dont now, if i can use the original ones with a new cam, intake, heads, header etc... or will they break or something?
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you can re-use them, unless you gernaded your engine, and worry about possible metal filings in the oil. in which case i would replace. but it sounds like you are just doing a cam swap, in which case you will be fine.
Car: 91' Camaro
Engine: Carbed 305
@dewey: no. im changing the heads, intake, tbi, cam, rockers, headers, pulleys. so i dont know if the orignal lifters would be so good with this stuff?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have doubts, get a set of OEM lifters and put them in. Might as well change them now instead of later since the motor will be apart.
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Roller motors you can re-use the lifters (as long as they're in good shape, not galled or anything). You can replace them if you really feel like it, but they're not exactly cheap. Flat tappet motors are a different story though, you never run old lifters.
dimented24x7
09-06-2015 03:51 PM
