305 truck heads
305 truck heads
ok guys i need help here. my friend and i are hoplessly in a debate about what valves were available stock in 305 heads. i say with the exception of TBI swirl port heads and 305 vortec heads, all 305 heads are about the same and ALL of them came with 1.84 intake valves. my friend says that the truck 305s were different motors and came with 1.94 intake valves, who is right? thanks guys!
Car: 4
Engine: 6
Transmission: 5
AFAIK no 305 heads whatsoever came with 1.94" intake valves.
However, some did come with 1.72" intakes, notably some of the early 2-barrel ones, including the ones in late 70s and early 80s trucks and vans.
There is considerable variation in 305 heads, especially the early ones.
So, both of you are partially off base. Sounds like your friend is worse.
Originally posted by 1MeanZ
anyone else?
anyone else?
ambainb
04-25-2016 09:21 PM
