IS THE COMP CAMS 274 TOO MUCH CAM FOR ME??????
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
It has a 230/236 duration. I want to keep the engine under 6200rpm. How will drivability be affected and will I have to run a brake booster? - Jesse
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, Holley Street Dom intake.
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Sounds like a lot of cam, however it really depends on LSA, doesn't it? Is it a 110 LSA? If so, expect vacuum at 14 inches or less.
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
I think you will probably be ok. It is a 110 lsa. You might have to idle it close to 900 rpm. I would make sure it installs at about a 106 or 107 intake centerline.
Car: 4
Engine: 6
Transmission: 5
I had one of those for a while in my 400. It was good in that motor. It will be alot of cam in a 350 but manageable with the other parts you have (the carb particularly). It ran really good, sounded like the engine was angry at something and wanted to jump up out of there and kill something... I liked it, until it committed suicide.
You'll definitely need a valve spring upgrade to 986s (head machine work!!) if you haven't already done it; your lift should be about .520" IIRC with the 1.6 rockers.
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Forgot to mention, the heads are the cast iron version of the center bolt aluminum vette heads. I think the only difference is the combustion chambers 64cc and 58cc for the vette.
Does anyone know the compression ratio for the 89' firebirds/camaros? I think it's either 9.3:1 or 9.5:1.
I've got the 274 in my 327 - and yes, like RB said, it sounds right. Eh, the same cam in a smaller motor gets increasingly hairy - so my 327 sounds like.....uh.......uh....
Music.
Hard-bitten-scream-at-your-brain-musical cacophony-with-a-formula-one-heritage-make-me-bad-scare-little-old-ladies-gearhead-lovin'-thumper-with-'tude.
Yup, that's it.
Do it.
BOR
