Advanced Timing Advantages
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I just read a post that Mad-Mic just made about advanceing his timing and what changes it made. I've always had that idea but im not educated in that area. How do you advance the timing on a electronically controlled car? My best friend has good access to 114 octane gas and i can get a good deal on it. If i use a 10/90% mix with that and the 93 octane that i always use, will advancing my timing hurt my car even if have no detonation?
I have a 91' GTA LB9 700R4 w/no cat, flows, K&N, TB Bypass, EGR Delete and a 160* stat.
I already posted this in the TPI forum and got no response.
Car: 1985 Iroc-z
Engine: 355 sbc
Just don't get crazy even if you have a higher octane, your engine is still working overtime to complete the firing process. Like a human who runs forever at a fast rate, he/she will tire n collasp =]
nhra-trans-am
Southern California Area
09-17-2015 10:16 PM
