Will this combo hold atleast 450 HP?
Car: 1991 Camaro RS
Will this combo withstand atleast 450 hp?
Keith Black Hypereutiectic Pistons
Scat 9000 Crank
Scat 4340 I-beams
Also are Total Seal Rings worth the $123?
Scat 9000 Crank
Scat 4340 I-beams
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
The 9000 series cranks are not forged, but cast steel. According to Scat, the crank is good to 600hp and 7500 rpm, the rods you mentioned are rated at 650hp and 8000rpm. So to answer your question, yes.
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
I bought a 91 Z that an eagle crank similar to the scat 9000 series. That scat could be better but the eagle crank almost cost me the whole engine. The crank ended up flexing under the 500 crank hp over several 1000 miles. This led to lost oil pressure and burnt up bearings and a couple of rods. I really think you'll be okay with the scat crank to 450 hp, but I wouldn't test it when you start adding more hp onto that. I was running this same scat crank in my 383/219/AFR/SR combo before I sold it. I never took it past 5600rpm but it worked good. I also made the mistake of using the stock 400 rods. Definitely get those rods you have listed they're very good. I guess the main question is what do you plan on spinning your engine to?
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
If a stock L98 can hold 450 than there is no reason that those parts shouldn't hold 450 either. I'm pushing slightly over 450hp at the crank on a stock L98. You just need somebody to build it right. Luckily - the guys working the GM assembly line on the day that my motor was built were doing things right.
Tim
Tim
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Originally posted by ede
i wouldn't run total seal rings in any steet or street/strip engine i also wouldn't run anything from scat, but that's just me and i don't know much
I thought scat made pretty good stuff?
Deffenitely not saying your wrong, just asking why.
Car: 1991 Camaro RS
Thanks everyone. Will keep the comments in mind. When I build this engine, I might use a forged crank and forged pistons to be safe.
well free i'm not saying i'm right either. just a few horror stories about scat parts is enought to keep me away from them. as for the gapless rings i just don't think they're needed, i would use them on a power adder application
Car: 2006 Silverado 1500
Engine: 5.3L
shouldn't be a problem holding up. i won't buy scat anymore though due to customer service being one of the worst i've ever dealt with.
Car: 91 Z28
Engine: Forged 383
Trax, remember, Scat castings aren't exactly the quality of the Generals.
RedLeader289
05-28-2019 01:47 PM
