rear gears
rear gears
I am thinking of changing gears to get a little quicker et. What would be the best choice for a car that is an auto and driven on the street all the time? What kind of price range am I looking at for a shop to do this and possibly add a posi unit?
1984 Camaro Z28
Crate 350
Edelbrock Intake
Edelbrock TES Headers
Hooker 3" Catback
ASP Underdrive Pullies
Corvette Shift Servo
JBL 150watt Amp
JL Audio 12" sub
1984 Camaro Z28
Crate 350
Edelbrock Intake
Hooker 3" Catback
JBL 150watt Amp
JL Audio 12" sub
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I would suggest 3.42's if you drive it every day.They give ya good out of the hole peformance and good drivability and mileage.The gears will cost ya around $200.00 and the install kit will cost around $100.00.Shops around here charge $200-$250 to set up the gears.I posi unit will be around $400.00 but you can get the take off posi's alot cheaper.Another option would be to check around the junk yards to find a 3.42 rearend.Around here ya can find them pretty easy and cheap,around $200-$250.If its not a posi get a powertrax for $315.00 and put it in.
Superman
Rev'n to Seven
Superman
Rev'n to Seven
Car: '00 Chevrolet Corvette
I've got 3.73s in the rear of my car. They're great. I really don't think you could go wrong with a 3.42 or 3.73, either one would be good for a street/strip setup. You'll get higher cruise RPM with the 3.73s, but I think the quicker acceleration is worth it. Definately get the posi unit too, with the steeper gears and the peg-leg differential you'll smoke the passenger side tire to oblivion.
-Mark W.
'88 SC Camaro w/ 305 TBI
-Mark W.
i have a peg leg rear, and am dying to get 3.42's(current ratio is either 3.73 or 4.11, i didnt install it, the guy before me got it out of the 'yard, and wasnt sure what ratio it is)anyways, is powertrax a company? is it posi? or better just used for the strip? i have a 10bolt rear, and my soon to come engine will have right at 450ft/lbs of torque.. will it handle it?
Car: 82 camaro SC
The powertrax is excellent street/strip unit. It will handle the power, but the rest of the rear end may not.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Put your car in drive, not overdrive, and get on the freeway at 70 MPH. Look at what RPMs you're at. Tell us the result and that'll be what gears you have now. For example, with my 3.45 rear end (swapped in a 9-bolt) I'm around 3450 RPMs at 70 MPH.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
What kind of et improvement would I see with the new gears and a posi?
1984 Camaro Z28
Crate 350
Edelbrock Intake
Hooker 3" Catback
JBL 150watt Amp
JL Audio 12" sub
1984 Camaro Z28
Crate 350
Edelbrock Intake
Hooker 3" Catback
JBL 150watt Amp
JL Audio 12" sub
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
or you can just jack up the back wheels and twist the drive shaft.
how ever many revolutions of the drive shaft it takes to turn BOTH wheels over once (wheels must turn in same direction) is your ratio.
you can do this and count # of revs in your drive shaft for 10 revs of your wheels and then divide by ten also if you want to be really accurate.
I say you might want to do it this way because if the gears arent origonal then the speedo will be off because if you change the ratio in the back you have to change the speedo gear in the tranny to correct the speed reading.
[This message has been edited by 88305tpiT/A (edited November 28, 2000).]
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
[This message has been edited by Pat Hall (edited November 29, 2000).]
hectre13
12-11-2023 09:14 AM
ambainb
04-25-2016 10:21 PM
hectre13
08-26-2015 09:17 AM
