OK, whats wrong with it? I can't wait t'il Im done!
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
When setting the TIMING, I need help. When I look down to my timing lines there is a "0" and looking towards the left,"a line", then a "4" then "a line" and so on.
Would that be the correct direction to set it towards?
I have read that i should set it to 6 or maybe 8 and the Chip would take care of the rest.
But when I reconnect that plug that Im suppose to disconnect before setting timing and then I go check it, the line is "way" past the timing lines towards the left, I can barely see it. It that normal?
Also I have raised the fuel pressure as far as I can get it, cause it hit my plenum.
I can only get it to about 45 with the vaccum line unplugged.
Im all lost here....I think I need more help...I got til Monday morning for work...
Oh god please help me....LOL...nah really HELP!...please.
What am I doing wrong?
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
1987 White IROC-Z
700-R4 auto tranny
97,000 miles
KYB's
Flowmaster Muffler
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Boush Patinum +4's
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
It's normal for the timing mark on the balancer to go way off the scale with the computer wire connected. That means that the ESC module is doing it's job, advancing or retarding timing based on input from the knock sensor.
As for the AFPR problem, I wish i could help you out but I have no experience with AFPRs. Maybe the others can help out here.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
Accel cap and rotor
Car: Take
Engine: Your
Transmission: Pick
As for the timing, that is normal, however, the ESC Module has no say in advance, only retard. But the computer will advance the timing once taken out of "bypass" (hence the name).
As for the AFPR, I'm sorry, but you are supposed to turn the screw IN to raise the fuel pressure and back it out to lower. You also should have ground out the bottom of the plenum for added adjuster clearance.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
