This should be the last ?, I hope!...TIMING, IAC, TPS.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Being that my car hasnt been cranked since last Sunday. I know the timing is probably off a little so my question is:
Should I just get the timing as close as possible (i dont have a timing light)
and then set the IAC and then the TPS?
What should I do?
Also I got one of those volt meters(not digital) from Walmart(cheap), will this work for testing/setting the TPS?
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Proted/Polished Plenum by "Daniel Burk"
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
What should I do?
1987 White IROC-Z
700-R4 auto tranny
97,000 miles
KYB's
Flowmaster Muffler
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Boush Patinum +4's
i don't know of any way to set timing with out a light with any degree of accuracey and you need a DVM not analog.
-=ICON MOTORSPORTS=-
1st & 3rd
1st & 3rd
Whoops,what i got is a DIGITAL MULTI-METER.
It says that I can check all kinds of volts, ohms and stuff.
I dont know what holes on the meter to connect the tester leads on.
When testing the TPS, what am I testing the DCV(ACV),DCA,Resistance,Diode or Continuity?
that way I will know how to hook up the METER.
Also on the dial what do I turn that to? It has a bunch of setting that I can set it to...
thanks
thanks
Wish,
You can try to set the timing by ear. Get it as close as you feel is correct. You can adjust the timing at any time without affecting the TPS and IAC/throttle minimum position adjustments too much.
When setting the TPS, connect to the top two terminals on the TPS using very slender meter probes, sewing needles poked into the back of the connector, or a special TPS breakout device. Use the DCV inputs on the DMM since you are going to measure D.C. voltage. Set the scale to the lowest possible range that wil measure at least 1.0 V. Your target setting should be 0.54VDC, +/- 0.07VDC. In other words, set it at 0.47 - 0.61 VDC, but try to get as close to the base setting as possible.
Once the TPS is correctly adjusted and the engine has been thoroughly warmed and is in closed-loop mode, you can set the throttle minimum air position. Some call this setting the IAC, but there is really no adjustment of the IAC stepper motor.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Later,
Vader
Vader, I dont know if it is the same on all cars, but on mine, you have to set minimum air first, then the TPS. Cuz if you adjust the minimum air, you are also re-adjusting the TPS you have already set.
1989 IROC-Z 5.7L
1989 IROC-Z 5.7L
Ok, I've got the connectors set.
on the meter **** the scales for volt checking are: RED V~ 600 or 200
White V - 600, 200, 20, 2
which one do I set it to. I am not electrically inclined. I never have been......LOL
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
You'll only be measuring tenths of a volt, so use the lowest setting the meter provides.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
