Anyone w/ Engine Swap Experience...
Hey guys, I have a 1989 Camaro RS. It came w/ the 2.8l MPFI, and I love the car, but the engine's gotta go! I would like to swap it out for a carbourated 350. Let me know what you guys think. Alright, first, I don't know if I should buy a new engine (the cheapest COMPLETE engine I can find is around 3k plus shiping) or if I should buy a rebuilt engine, or if I should pull a junkyard motor and have it rebuilt. I don't know what the cost of the second two options would be, or how reliable the engines would be. After that, I know for a fact that the tranny won't bolt up, so this brings me to another issue. Should I buy a rebuilt, stronger TCI TH 700-R4 (roughly 1,200-1,300 bucks) or get one out of a junked V8 Camaro and have it rebuilt. Again, I wouldn't know the cost of the second option. After that, I know I will need to get a complete exhaust (headers, y-pipe, cat, and cat-back). I have some questions. Would I experience any overheating problems due to the stock V6 Radiator and Fan? Second, how could I re-route/hook up the air conditioning? Third, I know I will need all V8 accessories, could you tell me all the accessories I need and which would be safe to get from a bone yard and which you would recommend getting new. I would also need a new flywheel. This is a huge project, and I am just trying to make sure that I have all my bases covered. If you guys see anything else or have hints/tips, let me know. I appreciate it!
Jake
Jake
WOW, that is alot of work! Unless this car has a special place in your heart it would be easier and more cost effective to sell your current Camaro and buy a factory V8 car. Just my opinion but believe me it is an experienced one.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified CHEVY DEALER Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Car: Transformed 86 Coupe
Engine: 400 sbc
I just finished the V6 to V8 swap on my '86. I would get the accessory brackets off of a V8 '89. I'm not sure but I think all of your stuff(alt, ps, a/c) should bolt up although you might need to swap the pulleys off of a V8 too. What side is your a/c on now? If it is on the drivers side you will need to get to get the hoses off/for a V8. As far as the radiator is concerned, the inlet and outlet are swapped on a V6. I would recommend a new one.
You will need motor mounts(the clam shell pieces that bolt to the crossmember) and inserts.
Good luck!
Good luck!
1 Post
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Thats a big swap. I pulled the 305 from my RS and installed a L98 TPI, then pulled that for a ZZ4. What complete motor for 3K? I paid 2990 for my ZZ4. Only thing you would have to add for your car would be some wiring and a carb, the ZZ4 is pretty complete. You could go with your existing car if you are going to do a simple carb engined swap. If you are going fuel injection, i'd trade your car for a TPI/TBi car.
Good luck
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Good luck
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Go over to the Motor Swap forum. This question is asked almost every day, and you'll see answers that are more complete, including questions you didn't ask but should have.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
If you get the accessarys off of 88 or later serpentine belt car be sure to get the water pump for the serp. engine. It is a reverse rotation water pump on 88 and later due to the serpemntine engine.
theshackle
03-05-2017 06:37 PM
