Is this the oil pressure sending unit on a 88 350 TPI?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, thats it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I don't believe that is it. I believe that is the fuel cutoff switch. The oil pressure sending unit is on the rear of the block behind the distributor.
Hank
87'IROC Z28
Hanks 87 IROC
Hank
87'IROC Z28
Hanks 87 IROC
Actually Hank, you're right, but it depends on the year. I forget which years, but the later engines, the oil pressure sender is above the oil filter like in the picture. On the earlier ones, its where you describe. Mine has a plug in your location and the sender is above the oil filter.
PS: 2000th post.
PS: 2000th post.
Ghettobird52
07-05-2024 11:18 PM
