Fuel pressure leakdown solved
1 Post
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I am one of many who converted from carb to TPI. I am also lazy and choose not to pull my tank again to install a fuel pump, so I went with the in-line pump.
Well, in-line pumps do not have checkvalves so the pressure drops to zero instantly when the car is off. Makes for extended cranking times.
I solved it by buying a $12 in-line ball check valve (brass) and installed it today. Guess what, it works! I'm so proud of myself. The hardest part was finding one snd I found one at this site:
www.mcmaster.com./
Do a search for "compact ball check valve"
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
www.mcmaster.com./
86 Camaro Sport
JM,
Thanks for replying with the results. This will be very helpful to remind us all that a good fuel pump is necessary for proper starting. We are always eager to blame a stuck injector or bad FPR for the inability to hold pressure, probably since none of us is fond of changing fuel pumps.
If I'm not mistaken, I recall the discussion about your fuel problem but I can't seem to fing the thread in the archives. If I gave the customary advice, I probably mentioned checking the fuel pump pressure and leakdown tests, including pinching the return and supply hoses. Sorry if I missed that one.
The McMaster-Carr catalog is a good source for a lot of hard-to-find parts. I use industrial suppliers almost daily, and another good source is MSC - http://www.mscdirect.com . They have a similar line of products. Between the two of them, Grainger, and your local industrial suppliers, you can find a lot of creative solutions to mechanical problems. Another good resource for locating products or companies is Thomas Registers.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
R3500
08-17-2015 12:16 PM
92camaroJoe
08-13-2015 06:07 AM
