hot start problem
Car: 87 camaro
Transmission: 5-speed
hot start problem
ive been having a problem starting my car after it gets hot. it would crank but take longer and longer to fire. i figgured it was the solenoid, so i replaced the starter. but i'm still having the problem.
i was thinking of getting the battery checked today, but the car starts right up when its cold so i dont think thats the problem. anyone have any other suggestions?
car stats:
1987 camaro
350 (tired motor) w/ edelbrock 600cfm carb
car stats:
1987 camaro
Car: 87 camaro
when its hot, the starter toils and cranks slowly but the engine wont fire for 10-15 seconds. depending on how hot it gets, the the starter will crank slowly but die, and the car will not start (but starts fine when pop-starting it rolling downhill).
i thought it was heat soak. starter had a lifetime warranty so it wasnt a big deal, but i thought it would have fixed the problem.
sorry i should have worded my post more clearly.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i have that same problem, i have a remanufactured starter, and it's wrapped in a heat blanket, will start fine when cold, after it's hot it tries to turn then pauses and tries again and fires
Car: 87 camaro
maybe i should have checked the timing after replacing the ign control module a few weeks ago.
i think its fixed now........... find out for sure tomorrow after i get it good and hot on my way to work.
theshackle
03-05-2017 06:37 PM
92camaroJoe
08-13-2015 06:07 AM
db057
08-11-2015 10:11 PM
