testing the oil pressure sending unit circuit
my gauge hasnt worked since i bought the car, its pegged. i want to make sure its the sending unit before it just replace it. if i unplug it, it should drop to 0. and if i take a jumper wire or paper clip and connect it to the two wires, it should go all the way up right? i did that but it stayed pegged when i unplugged it. any ideas?
I replaced my sender recently that was acting similarly. I did not try diagnosing the circuity at that time- jsut screwed in the new sender and turned the key- worked fine.
You might try buying a new sender and plugging it in before you physically install it in the block- just dangling in the air. If it doesn't read zero on the gague like that, you have wiring or gague problems.
I'm not sure jsut unplugging it is a valid zero-test. I know my gague will just sit where it feels like it with the key off. As soon as I turn the key on it will go to zero before starting it. I'll bet the circuitry needs current flowing through it even to zero-out the gague.
Ghettobird52
07-05-2024 11:18 PM
ambainb
04-25-2016 09:21 PM
