Pssssttt... MAF session --->
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Ok guys, here is the question. If a manfg. produced a MAF unit using the original circuitry, but increasing the diameter by 25% (this is arbitrary, I pulled it outta my.. er.. thin air I'll wait for some input on this number) could you still get by with your calibrated chip? Would an AFPR be enough to compensate or would you need a newer chip. If you incorporated a heated O2 sensor would the O2 sensor be able to sufficiently adjust the FI duty cycle to compensate? Or would you absolutely need a new calibrated chip along with larger injectors? Or any of the above singularly or mixed and matched? Let 'em rip!
Guest
Posts: n/a
Something would have to be recalibrated to let the ECM know there is more air going in. Otherwise, you are just lying to the ECM and it really isnt doing its job as designed. That means, in a perfect world you always change the chip when doing a mod. Of course we dont, and we mess with the timing and fuel pressure to work outside the computer.
In this case, I wouldnt do that, I would recalibrate. Keep in mind the table only reads to 255gm/sec, which IIRC is only about 420ish CFM, so beyond that you need a different calibration to provide proper fueling anyway. Someday, someone will mod the program like a certain Ford guy has done so the table doesnt stop at 255 and the ECM is capable of higher flowrates.
Car: Tree Huggers
Engine: Do Not
RD,
Max is right. The extra air flowing around the MAF at WOT would be great for those who need it. The extra air would be a disaster during closed-loop, however, since the MAF would report (arbitrarily) 25% less than actual air flow, making the ECM control fuel for a lot lower intake air. You'd be lean forever, and likely be the Supreme Allied Commander of the Code 34 army.
RD is on to a possible mechanical solution, and Max is very close to a final solution for our ECM problems. I wish I could tell you more right now, but I can't (RD might have a clue as to why).
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Later,
Vader
"Make Me Bad"
Car: Tree Huggers
Engine: Do Not
Ok, back to the grilling to get a clearer pic...
If the MAF diameter is increased by 25% and airflow is increased by 22% (mind I'm not too good in fluid dynamics but we'll say about that) from the increase in diameter, could you have the chip calibrated to have the same increase in fuel delivery? Or rather, could you have the chip compensate for that extra airflow?
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Anyone ever thought about using 2 MAF units and then researching the circuitry for the MAF to only send HALF of the signal back?
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.587 @ 107.97mph (1.710 60ftr) on the long runner setup.
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels. Stock Wheels. No Weight Reduction.
Gunning for NA 11's with the MiniRam II and Hooker LT Headers.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
Tim
Car: Tree Huggers
Engine: Do Not
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
the Buick guys have an translator that lets them run lt1 3" and 3.5" mafs on their cars. So we know it can be done. I think that would be the direction to go.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP cam, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax/Flowmaster catback
Coming Soon - Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - STOCK (for now)
SOLD ->91 Z28, 5.7, 3.23, Ported Plenum, Accel runners & lower intake, Accel distributor module, !dual cats, POS Edelbrock catback, K&N'S, ram air, tb airfoil, !tb coolant
Car: Tree Huggers
Engine: Do Not
BTW - Max, hows the LTR stuff coming? I may have a new idea for ya to try if you feel like putting something together. If your near MA we should hook up and compare notes. I'm basing most of the stuff on my little 383, but I'm sure this could be uased for any 8 cyl chev.
Guest
Posts: n/a
RD, right now I'm at a standstill. I'm in my last semester at school and dont really have the time to do what I want to do. The manifold base I did install on my TA before I changed the engine, and the Gtech I have showed a solid .5 difference. Before I yanked the engine I put the old original base back on and I lost the .5
I plan on taking another TPI car I have (Grand Prix) and running it on a dyno as is (stock stuff), with my modded base, and hopefully with an aftermarket part to be named later
Granatelli doesnt make a better MAF for our cars. There is a Wells unit that flows more, but the ECM is a limiting factor anyway. A translator might be an option at this point, the Turbo Buick guys seem to be getting away with it and reprogramming.
Car: Tree Huggers
Engine: Do Not
Max, every time we chat you get my creative juices flowing, as well as my curiosity! Five tenths is nothing to sneeze at at all! I'd be very interested in those dyno numbers. I wouldn't knock the G-Tech times either. Both times were taken with the same instument, so you can assume a very close to true value.
On another note. Anyone know the percentage increase in fuel flow when you swap out to Ford 24# injectors? (assuming the same rail pressure? Also, anyone any good in fluid dynamics? Man, now I wish I didn't cut class in college all the damn time!
The MAF translator (I believe once offered through Painless Wiring) was for the digital MAFs on 231 Buick engines.
Concerning the rescaling of a pair of analog MAFs, the circuitry to A/D convert, add the two signals with an op-amp, and D/A convert a scaled signal would fit inside a cigarette pack and cost about $50.00 in parts, tops.
A similar circuit to rescale the output of a larger MAF would do the same. The trick would be to measure the intake flow accurately to scale the new MAF output properly - a good use for the original MAF, I suppose.
You still aren't quite getting the solution. I'm working on an email to the Red Devil. We may have a business proposal that doesn't involve fiberglass bodies.
Later,
Vader
"Make Me Bad"
Later,
Vader
"Make Me Bad"
Car: Tree Huggers
Engine: Do Not
Ok, anyone else want to add to this? Maybe answer some of the questions above? Anyone have a definitive explanation on MAF operation? I can only get old archive searches working, so I can't seem to find that nice long post we had going on the diferences of the two thirdgen MAFs. C'mon guys I need some help on this here subject to make some things happen!
If you have a problem,
If no-one else can help,
And if you can find them,
Maybe you can hire....
THE A-TEAM
Men,, I'm soaking this in big time. I'm running a stock 305 chip in a 86 with a pretty hot 355 and 24# injectors. Dang thing will fly WOT (good plug burn), but the rich idle is killing me. Thanks for posting this discussion. It's got me thinking - - and I'd be interested in the product(s) if you all hash one/some out!!!
86 IROC - 9.8:1 - 355, TFS twisted wedge heads, 218/228-110, fully ported GM base and plenum, SLP runners, 52mm BBK, 24# SVO, 1 5/8" Headman headers, 3" Dyno-max, TH350, B&M Megashifter, 245/45ZR17s on 212 Eagles
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Jim85,,, I'm an old timer and a carb guy, so this is really frustrating to me. I can tune a carb,, including the computer quads. There's no programming involved there,,, so no problem. However, I'm at the point of no return and sunk way to much time and money into the TPI set up (more than I have to spend). I keep telling myself to hang in there,, especially since I've driven it with the TPI set up and know this thing will go,, and it can't help but get quicker with a properly calibrated "chip".
Wish I could help you,, I did however change every stinking sensor on this thing.
[This message has been edited by BadSS (edited October 12, 2000).]
Car: '87 IROC-Z
Red Devil - check out www.modernmusclecar.com for the maf translators. Maybe they can help out w/ a program or something to convert the data stream to one our cars can read.
Car: Tree Huggers
Engine: Do Not
Hey Bad and Jim, you guys know your rail pressure?Start up a thread with both cars' info and let's see if we can rid ya of your gremlins! Have you guys shown any codes?
Car: Tree Huggers
Engine: Do Not
Allright, to revisit this lets cover some outstanding questions as well as some new ones.
-The 255 gm/sec limit of the MAF. ECU reason or chip reason?
-By the time the MAF reaches that 255 gm/sec. limit (on a stock 350) what % is the
throttle open? How about on a 383 or 400?
-Max, can you elaborate on this Ford guy??
-Can a chip recalibration compensate for the increased airflow even if it does not 'register' through the MAF?
-Anyone know the percentage increase in fuel flow when you swap out to Ford 24# injectors? (assuming the same rail pressure)?
-Anyone have a definitive explanation on MAF operation? I can only get old archive searches working, so I can't seem to find that nice long post we had going on the differences of the two thirdgen MAFs.
-Vader, wanna clarify this:
"...Concerning the rescaling of a pair of analog MAFs, the circuitry to A/D convert, add the two signals with an op-amp, and D/A convert a scaled signal would fit inside a cigarette pack and cost about $50.00 in parts, tops.
A similar circuit to rescale the output of a larger MAF would do the same..."
I can get access to a flow bench so I could get a few sets of numbers.
The IROC Homepage
Car: Tree Huggers
Engine: Do Not
Originally posted by Jim85IROC:
My rail pressure seems to be a bit of a mystery. See. Nothing is ever easy. It is 45lbs no matter how far I turn the afpr screw in either direction.
[/B]
[/B]
It's just not that difficult if you have the spare time. The problem is that the ECM will still only supply fuel up to the 80% duty-cycle limit, regardless of the air intake volume.
Later,
Vader
"Make Me Bad"
[This message has been edited by Vader (edited October 16, 2000).]
Car: Tree Huggers
Engine: Do Not
Yee gads!! Ok, I knew I liked you for more than your looks!! I need to absorb and then fix up some answers... er... questions... The only one that pops out at me was the SVO injectors. I was hoping someone would have a difinitive answer because the ford injectors are rated differently and I keep finding different numbers.
Also I have a call in to Wells... we'll see what that leads.
BumpaD82
02-26-2016 02:57 PM
