Failed emission test....hydrocarbon help..
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
Grrr, failed emissions with the IROC hydrocarbons were high. I figured it needed a tune up anyway but wanted to try the test first. I just got done putting plugs,cap,and rotor in.
Think it'll pass now?
The std was 1.4gpm and mine was 2.09gpm
Man I almost for got the plugs on it were a semi pita to change....
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You could turn down the pressure, but that has the negative effect of reducing the misting.
If you really want to make sure you pass, put in 305 injectors.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 03:56 PM
