please please tell me theres some other possibility
Old 10-09-2000 | 08:32 PM
CamaroZ_85's Avatar
ive noticed a bit of oil consumption in my baby lately...i didnt really think it to be anything serious since i get smoke at startup cause of the valve stem seals. but i was bored today so i hunted around for a while...unplugged the pcv, checked for vacuum...got plenty there. left the pcv out for a min and watched very closely...what did i see but a few whisps of smoke i lost the original LG4 to bad rings (due to bad detonation that went uncorrected...hey, i didnt know back then) since i dropped this 350 in latel july, ive been hearing detonation on and off, while trying to get the best out of my timing/advance curve etc. of course i dont beat on it when i hear it ping, i go and fix it. but now im just afraid i did it again...it would break my heart to see i had bad rings. the short block supposedly had 15-20k on it and seems great. the smoke on start is because the machine shop screwed up the valve seals in the heads, i dont want the hassle of taking them off to have the shop do it again. anyway, i want to know if there may be any other possibilities aside from bad rings to cause that slight blowby.
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old 10-09-2000 | 11:03 PM
JETHROIROC's Avatar
I'm thinking leaking/worn valve guides can be a possibility, especially if you're seeing smoke out the PCV grommet. Using your vacuum gauge, check for a rapid vibration of the gauge needle about 4in.Hg back and forth. Get back to us and we'll try to help.
Old 10-09-2000 | 11:06 PM
Colin 86&87 IROC-Z
Guest
Posts: n/a
i'm having a similar problem with my fresh rebuild on my 305.. 4000 miles and i'm smoking on startup.. gotta love idiots that don't know how to do valve guides.. i've been having a pinging problem too, i hope it's just gas..
Old 10-10-2000 | 12:39 AM
CamaroZ_85's Avatar
ive been running 92 octane the whole time, changed to colder plugs...put in a 160 stat cause its hard to keep the motor cool. none of that really helped
LC2 TECH
10-13-2015 11:53 PM
HoosierinWA
10-07-2015 10:15 AM
oil pan 4
Fabrication
10-06-2015 11:56 AM
Agent507943
Camaros Wanted
10-02-2015 07:17 AM
mfp189
09-27-2015 09:25 AM
Quick Reply: please please tell me theres some other possibility
