Cam Upgrade on a LG4- which one??/
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Ok guys- got a full exhaust, i could put headers on it, and i pretty much plan on getting either a performer or air gap intake... heads could be ported, if it would be worth the bucks.
basically, these haeds i am getting free, they were rebuilt about 5000 miles ago. so they have to be cleaned up, and could be ported for about 150 bucks i think. Worth it?
Plus, I REALY NEED IDEAS FOR A CAM... i have no clue what to get... i will be using the computer sooooo.
thanx guys- steve
86 Firebird, LG4, t-tops, 2.73 open rear, SLP 3 inch cat back exhaust, catco cat, Coming mods: GOT A 350 IN THE WORKS BABY! gonna throw my TES edlebrock headers on it, and hopefully get some more gear and the cowl hood on
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.8 on the motor, 12.89 on NOS and slicks! Hit by what else!?!? a FORD EXPLORER!!!!!!
thanx guys- steve
A good entry-level performace cam from just about anyone would work better than the stock one. Something with about 260-270 intake duration, little more on the exhaust.
Don't go crazy with cam duration cause the motor doesn't have much compression (about 8.5:1) and a bigger cam will kill cylinder pressure making the thing a dog on the street.
94 Firebird Formula M6- No options but Z rated tires. No mods over $10. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, tweaked QJet 4bbl, finally a decent set of heads, a few other tricks. A maddening 13.000001 @ 108 on the motor with little traction. No nitrous runs with the new heads yet.
Grandma's old 78 Malibu (33K miles!) soon to have the powertrain from the 79 put in it.
"One of the last remaining QJet tuners on Planet Earth!"
Daemon- Didnt the 85 lg4's and earlier have the lower compression?
when i did the compresion test, and did some math i got 9:1 for the compression ratio.... Any how, thats a lot of duration... i was thinking something along the lines of a 420/440 lift and 218/224 duration... and a 110lsa.... sound like something decnet? just want to get the most bang for the buck here
Steve
Steve
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
nope your's is 8.5:1
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Crane's Compucam 2040 looks like a good canidate. I wouldnt goo much bigger then that unless you have 3.73s or a high stall TC.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
ok, well the compucam 2040 looks realy good- but what do you guys think- 2030 or 2040??
2030:
Degrees Durration @ .050 - 204/214
degrees advetised- 264/274
Lobe Seperation- 110
Lift- .423/.446
2040
Degrees Durration @ .050 - 210/216
degrees advetised- 270/276
Lobe Seperation- 114
Lift- .440/.454
Now the biggest difference as i see it is the lobe seperation... 110 vs 114. can anyone tell me what that will change or do?
i think i am leaning more towards the 2030, to keep some driveability, but crane also makes hi intesity lifters, that below 3000 rpm, reduce duration and lift... would that be a solution to this.. cuz i really wouldnt mind throwing the 2040 in.
Steve
Steve
2030:
Lift- .423/.446
2040
Lift- .440/.454
Steve
Steve
Car: 4
Engine: 6
Transmission: 5
My recommendation would be a Comp XE262H. Check the specs on their web page. Some other people on this board have used this cam in that motor and love it. You will definitely need headers for the cam to do its job: the TES is an excellent choice. If at all possible, DON'T get the one for the LG4, because it is designed to hook up to the stock exhaust pipe which is dinky. Basically you'll have a big exhaust next to the heads, and a big exhaust behind the cat, but a pinch-off at the cat because it will be 2½". Get the TES for a L98 instead, and a 3" cat of course.
You really should lose that grocery-cart gear... you wouldn't believe how much difference a set of decent gears makes. You'll probably get more resuts from that than you will from a 350 or a cam or almost anything else you can do under the hood.
well, i have an slp 3inch cat back with a 3 inch cat, hooked to the stock y pipe!! so anyways, i have the l98 headers...
yeah if i can get my hands on a used diff, i might consider putting in some used 323's that i got
Steve
[This message has been edited by fb305svs (edited October 06, 2000).]
Steve
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Do you have to go through an emissions test? If so, the milder cam would be most likely to pass. Others have said you can get through with the performance-oriented cams, but you have to decide how much hassle you're willing to endure.
Also, if you have emissions testing, the Performer is the only one that will pass visual. The Air Gap would probably have problems passing at idle, even if it's only a sniff test.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 open. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, ported heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
yeah there is no visual here yet! basically, i am just makeing the car seem better than it is for when i sell it. the car smokes bad on start up, and to alleviate that, i have set of heads for it. can't beatthe price of them- free. so i got to thinking what kind of options i got etc while i got it torn down. cuz it has a BAD lifter tap in it. so anyways, just tryin to get ideas. i dont want to spend mucho money on it cause i plan on selling it in the spring to get a nicer car, like a 88-92 formula or trans am.. but either model i want the 350
Steve
Steve
Car: 1986 Firebird
Engine: 2.8 V6
There's no visual in CT? A guy on the v6 board said he couldn't replace his 2.8 with a 3.4, because of the visual. Hm. I'll pass that info on, thanks!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
yeah there is NO visual in CT. they tried to open my hood when they did the safety inspection on my car and ran out there and told them if they opened my hood they were not going to have a job any more. its a SAFTEY inspection. they look for rust, a cat and test the brakes and make sure the lights work. THATS ALL.
As long as your car passes the sniffer test then you should have NO probs. you just dont tell em that you got a 3.4 to begin with. and you can get away with it for now cuz they dont test flow numbers...
Steve
Steve
Car: 1986 Camaro SC
well steve they probably wanted to open your hood to make sure you had a battery tie down, cause that's what they did to me.
I have the comp XE262H mentioned above and i love it. the only problem is my 3.08 gears, they kill me...one day ill toss them tho, im actually looking to build up a whole rear. anyway, my point is thats its a good cam...you'll **** your pants the first time you start that baby up, its nice...pulls hard as **** too.
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I have a cam w/ nearly identical specs to the 2030 in my 305 TPI. Idles and drives fine but made a big difference over the peanut cam. Worked well w/ the stock chip and w/ the ADS chip (no real change at part throttle in that chip anyway).
For me, I kinda wish I had of gone w/ the 2040. The 2030 is too tame IMO for what I wanted. The 2040's specs look about like what I'd try if I had it to do over again. I do have 3.42 gears though...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
[This message has been edited by Ray87Z (edited October 07, 2000).]
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Engine: LS1/LQ4
You're doing this to get it ready to sell? Heads are one thing, which I can understand to stop the smoking at startup, but doing the cam is a lot more work than heads (although that's the right time to do it if you really want to change the cam). Throw in a set of lifters on the old cam while the intake's off to stop the tapping noise (no, it's not guarenteed to eat up the cam).
Do the heads, but save all the good stuff for your 350 car.
[This message has been edited by five7kid (edited October 07, 2000).]
The Competition Cams 268H10 has always been a favorite of mine for a street car with an auto transmission. Check it out:
http://www.compcams.com/speccard/12-210-2.txt
yah, i thinking that im jst goingto do the heads, and maybe the cam if this car i am looking anow doesntwork out. sounds like the 2030 cam would be the best bet, since i have no intent of changing the gears now. Hey chris still got that cam, chain and lifters???
Steve
Steve
Car: 1986 Camaro SC
i have the cam and lifters, but i dont have the chain... it was stretched
ok.. i might be callin ya hey ya think that chain might be streched from missing 3rd a few too many times????
Steve
[This message has been edited by fb305svs (edited October 08, 2000).]
Steve
Car: 1986 Camaro SC
nope i never miss 3rd, that was only cause the clutch was messed up, no i hit it everytime that was from 5500 RPM Dumps
