How can I make this engine work in MY car??
Old 10-08-2000 | 01:47 PM
89ROC's Avatar
OK, I want to get this block for my 89' IROC--->
Rocket block, 4.00*4.125 = 415 cid
Block Price: $2,119.95
Part # 22551788
Bore as Shipped: 4.000"
Max. Bore: 4.190"
Max. Stroke: 4.125"
Main Bore: 2.450" (350)
Oiling Type: Wet / Dry
Deck Height: 9.025"
Rear Seal : 2 Piece
Main Caps: 4-Bolt Splayed
Weight (lbs): 200
Technical features of the Rocket Block:
Steel Main Bearing Caps
Reinforced Decks
Siamesed Cylinders
Relocated Camshaft
Big Block Cam Bearings
Spread Pan Rails
Priority Main Oiling
Dual Starter Mounts
Mechanical Fuel Pump
It will bolt right in except for 1 thing... It has a 2-piece rear main seal, which means that the flywheel bolt-pattern is different.
How can I MAKE my T-56 flywheel bolt up to this block?
OR, better yet, is there a way to *convert* this block to a 1-piece rear main, so my flywheel will bolt right up?
AKA Pony Punisher II on all other boards.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
A4, bone stock except for the Flowmaster.
[This message has been edited by 89ROC (edited October 08, 2000).]
Old 10-08-2000 | 02:11 PM
ede's Avatar
ede
moroso makes an adapter to convert to 1 piece rear main seal. not sure about balance issues though. i think if you have a 2 piece rear main seal your flywheel will have a differant balance then if you have a 1 piece seal.
-=ICON MOTORSPORTS=-
Old 10-08-2000 | 02:26 PM
FormulaJoe's Avatar
I believe centerforce makes a flywheel that will work. Give them a call.
L98, stock 3.27s, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). And just recently T56!
Old 10-08-2000 | 02:31 PM
89ROC's Avatar
ede-This must be what you were refering to http://www.jegs.com/cgi-bin/ncommerc...archresult=yes
The only thing it does is it allows you to use an old-stlye crankshaft in an 87-92 block.
Guess I'll look up Centerforce now.
Thanks!
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
1997 black Trans AM
Old 10-08-2000 | 06:38 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Just buy a flywheel made for a 2 piece rear seal crank. They're pretty cheap, and alot of people make em. I think I got mine for under $100, but I can't remember. Mine was for an auto, not sure of differences for the manual trannies. I was thinking the t56 used the same flywheel as the T5s, so they shouldn't be hard to find.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old 10-08-2000 | 07:05 PM
89ROC's Avatar
Nope, the T56 flywheel is totally different than the T5.
However, I found that Centerforce makes a T56 flywheel for the old-style 2-piece rear main blocks.
-Thanks everybody!
89' Iroc-Z
NOS 150 shot.
95' T-56, 6-speed
1997 black Trans AM
Old 10-08-2000 | 08:16 PM
Mike-91 Formula 350's Avatar
A Rocket block is not the same as a regular chevy block.I believe the deck is taller and the cam centerline is raised for increased stroke or something like that.434's are made out of those blocks on a regular basis.If your planning on making more than 700 hp.its the way to go but up to that point a bow tie sportsman block for around $1600 is a good choice.Or if your 500 hp.or less go with a production 400 block.
midge54
12-27-2019 04:14 PM
TheExaminer
08-26-2015 04:59 PM
mustangman65_79
08-11-2015 03:17 PM
milk
08-10-2015 06:26 PM
Quick Reply: How can I make this engine work in MY car??
