Valve adjustment
Valve adjustment
Took off my head last night to change a head gasket. Loosened each rocker exactly two turns. when i put the head back on and retightened them 2 turns. now all the rockers are tight enough you cant move them by hand except one just wondering if i should have more than just one that is loose dont want to start the motor and screw the valves up please help out asap as i would liek to have it together soon. thanks...
Guest
Posts: n/a
your goig to have to set the vavle lash bet way to do it (from what i have laened on the board) is to lossen't then all up till you barely touch the pushrod. start the motor (DO NOT REV THE MOTOR) and tight them down till you hear the tapping stop
if you have any more ??? do a search for "Valve lash" or "0 Lash"
Hotrodboba400
12-10-2019 07:07 PM
dimented24x7
09-06-2015 03:51 PM
