Plug Identification Needed, Pics inside
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
What are both of these plugs?
<img src="http://elite-fraggers.org/sonarun/TransAm/Serpentine%20Swap/Finished/06290013%20(Medium).JPG">
And this one..
<img src="http://elite-fraggers.org/sonarun/TransAm/Serpentine%20Swap/Finished/06290014%20(Medium).JPG">
What does that wire on the radiator go to?
<img src="http://elite-fraggers.org/sonarun/TransAm/Serpentine%20Swap/Finished/06290016%20(Medium).JPG">
The car is a 1986 Trans Am. The engine was orignally a LB9 and its a 165ECM car. (MAF)
For the rest of the pics..
<a href="http://elite-fraggers.org/sonarun/TransAm/Serpentine%20Swap/Finished">Click Here</a>
And this one..
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
The plug in the first pic if i am correct is located on the passanger side which goes to the tempature fan switch sensor located near the back of the block somewhere near or in between spark plug wires 5 and 7. Not sure what the other one is though.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I don't think that is the fan switch connector. Mine looked totally different ('83 Z28).
First pic (single wire). EGR feedback diagnostic switch connector
The two wire might be for the MAT sensor located on the bottom side of the plenum, driver side.
Second pic....Oil pressure switch, maybe not too sure on that one.
Third pic looks like a thermal switch for controlling an after-market fan, or maybe a thermocouple for an after-market temp guage.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
When I was doing my TPI conversion, I had to get a new brass fitting from a TPI car for the oil pressure gauge and the one I got had the oil pressure sender and the oil press switch. switch had 2 terminals on it and that connector looks like it is for that.
Car: '86 T/A
Oil Pressure Switch eh.. well that may explain why my oil pressure always reads over 90. I replaced my oil pressure sender and that didn't fix it.
But it will cause you to have long crank times to get the car started, 10+ seconds.
Re: Plug Identification Needed, Pics inside
And this one..
And this one..
Switch doesn't affect the oil pressure reading, sorry
Car: '86 T/A
Just the LT1 intake.
<img src="http://elite-fraggers.org/sonarun/TransAm/Serpentine%20Swap/Finished/06290022%20(Medium).JPG">
On the brass fitting that is coming up from the back of the block where the oil pressure sender is, there should be a "Y" block with the sender on one end and the switch on the other end.
Reach down in there and see if you can feel it.
It is about an inch in diameter and about 1.5 inches long with two prongs sticking out of it. It is a silver grey color.
Car: '86 T/A
Thats wierd, I don't see anything like that on my car. Whats even wierder, I don't see any mention of an oil pressure sender or switch for that matter in the Chilton or Haynes manuals.
Zachattack0925
08-12-2015 09:52 PM
