My car will not start-VATS problem I think!! Please Help!!
Hi all. I recently bought an 89 Trans Am, with a 305TPI/auto drivetrain. The steering column, ignition is tore all apart. I researched and found out the values for the VATS passkeys, but I don't have a key to go by. I can still turn the ignition with pliers, I have the VATS wires from the ignition, down and jumper wires ready to hook to various resistor values. I can here the fuel pump come on but the car won't crank or fire at all. Could something else be killing me? Any help is appreciated.
Thanks, Brandon
Thanks, Brandon
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I guess the Neutral/Saftey switch would stop the starter from cranking. Check to see if your rear hatch will remotely open. I had that problem once.
I don't think the park/neutral switch is the problem. As I said, the steering column is trash, and I think it is definately a VATS problem. I bought the car for reasonable price, but I don't have a key for it (not that it matters, the ignition is all tore up). I have tried the resistor value substitution on the VATS wires, but I still can't get the car to crank/fire. Please help a guy out...
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
VATS can disable the starter as well as the fuel injectors, not the pump. If you don't have a key, take your VIN (registration card too) and a driver license to a local GM dealership. They should be able to make you a factory key for it if you give them your VIN. If the car has VATS they should give you a VATS code with the key. They MAY not be able to give you a VATS code. If they can't get your VATS code, then you'll probably have to burn a PROM without VATS in it. Be warned though, a VATS key costs about $30 from the dealership, $5 without VATS. If you can get the VATS number for your car, then you can get the resistor values, bypass it, and then get yourself the $5 key. Hope that helps.
Ghettobird52
07-05-2024 11:18 PM
db057
08-11-2015 10:11 PM
