problem with MSD bulk wire set
i ordered a set of 25' wire (#34019) and 90* terminals and boots(#3311). i crimped one terminal already but when i try to squeeze it into the boot, its too tight and eventually wont move. i removed it and the wire came right off the terminal. is this how it's supposed to be or do i have a mismatched set?? i dont see any other way i can get the terminal into the boot since it's at a 90* angle.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
sounds like your crimp isn't as good as it could be. i use a little screw driver to push the terminal into the boot enough to grap it with needle nose pliers and pull it rest of the way through.
1992 Trans Am
05-10-2023 07:19 PM
db057
08-11-2015 10:11 PM
