Choppy Acceleration
Old 06-24-2003 | 01:44 PM
TBIfly's Avatar
Choppy Acceleration
When I step on it, the car jolts or "burps" and then it catches itself and chirps the tires....in higher gears, at higher speeds....upon acceleration it does the same thing but not sucha hard jolt.
I've also noticed that my tach will bounce steadily over a 500rpm or so stretch.
I've replaced the fuel pump, and fuel filter, I dont know what else to check, i will be checking my plug wires in a bit.
Any suggestions?
Old 06-24-2003 | 02:43 PM
Morley's Avatar
Sounds like it might be a vacuum leak.
Which car in your sig is this on?
Old 06-24-2003 | 04:49 PM
TBIfly's Avatar
its the 91 RS
The car also does it during idle, the RPM needle fluctuates, although not as severely
Old 06-24-2003 | 04:52 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
bouncing tach is a pretty good sign of a vaccum leak
Pac J
05-17-2020 11:44 AM
db057
01-10-2020 09:55 PM
RedLeader289
05-28-2019 02:47 PM
Spyder_TheGamer
10-02-2015 01:25 PM
ULTM8Z
09-16-2015 10:15 AM
