What Heads for a 350
Car: 1991 Camaro Z-28
Transmission: 5 Speed Manual
I am building a 350 to put in my 91 Z28. I will use the 305 TPI unit. What heads would be the best for about 300 325 HP? Would the L98 heads be the best for this combo? Also headers, and a cam. Any suggestions?
- 1991 Z28
- Ultra Metallic Blue
- 305 TPI
- 5 Spd Manual
- 3:08 rear axle
Well, the L-98 heads would certainly make the swap easier since they were designed to work with TPI intakes. A little porting, some fresh springs, bring them back to flat with a little milling and you're in good shape. Not the highest performing heads out there but should be cheap to lay your hands on a decent set.
Cam- shoot for about 210-220 intake duration @ .050", little more on the exhaust side with a nice wide 112-116 lobe separation and you should get good results. Its mild enough that you could probably still get by with a stock chip in the ECM (but more on that later).
Exhaust- no big deal. 1 5/8" or 1 3/4" headers into a 3" cat and cat-back. SLPs are REALLY nice headers but $$$$$. Edlebrocks are a little more reasonable and still stainless steel. Lots of other choices out there. Might want to have whatever you get "Jet Hot" coated to keep the heat IN and the rust OFF.
If you are using the stock 305 TPI's (19lb) injectors then you will need to increase the fuel pressure from ~42 PSI stock to about 55 PSI to compensate for the extra displacement they need to feed. Or drop in a set of 22lb 350 TPI injectors.
But considering you will have undersized injectors and an aftermarket cam you might just want to go with an aftermarket chip to bring all this together for you, tuning-wise.
94 Firebird Formula M6- No options but Z rated tires. No mods over $10. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, tweaked QJet 4bbl, finally a decent set of heads, a few other tricks. A maddening 13.000001 @ 108 on the motor with little traction. No nitrous runs with the new heads yet.
Grandma's old 78 Malibu (33K miles!) soon to have the powertrain from the 79 put in it.
"One of the last remaining QJet tuners on Planet Earth!"
I would go with a set of AFR 195 heads, a set of SLP 1 3/4 headers, a 3 inch cat back (edlebrock, hooker, flowmaster, random tech, ect.), and a the LT4 cam or the ZZ9 cam.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
L98 TPI 350 (5.7L)
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Darts the best heads for the cash man. I agree that the SLPs are the best headers. LT4 hot cams are good, but i have heard that they have problems with the heat treating on them and that they grenade in engines. check it out before you buy. Comp, Edlebrock, or SLP make cams. TPIS is big into thirdgens and they have cams too. Talk to them and see what they think.
[This message has been edited by 88blkiroc (edited September 28, 2000).]
for a street 350 AFR 195 or Darts are a bit exsecive. a set of aluminum L98 heast will do the job perfectly. have them rebilt. you can pick up a set of Myron at TPIS for $500 rebilt
when the green flag drops the bull$hit stops
350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
theshackle
03-05-2017 06:37 PM
NinjaNife
08-23-2015 11:49 AM
