305 suggestions, other than get a 350
1 Post
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
I have just dissasembled an 84 l69 (305 HO) engine with 85,000 miles on it. It's very cherry. The valve job will cost $60.00, and the total budget is $360.00 So you have $300.00 left, make the best of it. You will ahve to use the stock manifolds with a hi-perf exhaust system and no-cat. The car is going to use the q-jet and the computer. When all is spent the motor has to be complete and ready to run.
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
camshaft definately, then if there would be money left from exaust, get those heads ported, thats what i would do, you could also up the compression with some higher comp pistons
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
A set of 3.42 gears would be nice.
But since you have the engine apart it is wisest to port and polish those heads and go for a better cam and lifters. Might I suggest you follow the parts in my sig? And also follow the link at the end of my sig for a good how-to on porting your heads.
Good luck and feel free to contact me if you need help
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
Porting is FREE if you do it yourself do the intake and heads. Buy a cam and spend the rest of the money on gaskets, rings, bearings and other et ceteras...you will eat that budget up quickly.
Running a non computer controlled quadrajet is another cheap option, ditching the computer allows the use of a more radical cam, that's what I did.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Cam, lifters, timing set, valve springs, ignition coil & module.
Nothing is "free", including porting. You'll use up stones & rolls, and last I checked, I had to pay to get/replace them.
When you get another $400 ahead, do headers.
The CC setup will handle plenty of cam. Mine idles at 500 in D, and revs happily to 6000.
Car: 84 Z28
Well if your dad has the attachments for the grinder already, it is effectively free for me.
Seriously, I don't consider tool purchases part of an engine buildup. That's just me though, I guess you could take into account depreciation of the garage if you want to nitpick.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
strange..... i KNOW that somewhere in this thread i had replied...
heh, probly got deleted because i started out with a smartass comment...
theshackle
09-17-2020 08:26 AM
theshackle
03-05-2017 06:37 PM
NinjaNife
08-23-2015 11:49 AM
