MY MOTOR EXCHANGE
MY MOTOR EXCHANGE
I HAVE A 87' CAMARO Z-28 TPI THAT HAD A 305 IN IT I GOT A 350 OUT OF A 89' CAMARO AND INSTALLED IT. MY OLD TPI AND INTAKE HAD INJECTOR FOR COLD START AND ANOTHER PLUG FOR TEMP READING, THE 350 I HAVE NOW DOESNT, AND THEY ARENT PLUGGED UP. MY ? TO YOU IS WILL A 87' 350 INTAKE HAVE THE CLOD START AND THE TEMP READING AND IF IT DOES WOULD THAT WORK ON MY 350? SORRY IF THIS IS A STUPID ? THANKS FOR YOUR HELP
put your old manifold onto the 350, there is no difference in the 305 and 350 intakes. the only difference at all is the injectors. I believe the cold start injector was used through 88 and dumped in 89. Kyle
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
Kyle Osterholt
Okarche, Oklahoma
86 T/A 383 TPI
80 T/A Pace Car
73 Opel GT
they are wrong, 87 and up all use the same angle and even at that, you'd just have to elongate some holes if you had an 86 or older intake. up through 86 all the intake bolts sat at the same angle. In 87 they made the center 4 (2 on each side) stand more vertical than the rest, probably for easier access to be tightened. cya, Kyle
sailtexas186548
08-24-2015 10:11 PM
