How can I run Consistent 14.50's in a 350 GTA?
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I have an 89 GTA, L98, auto, 3.27 posi rear. It is all stock besides MAF screens removed. Thx guys!
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
headers/catback, and a highflow cat, slp or accel runners..... good tune up, free mods like ignition timing, chip..
Steve
Steve
from my own L98 and others i've saw run i'd go with SFC's, air bags, lca relocation brackets, and slicks or drag radials. the L98 makes enough power to run in the 14's the key to running 14.5's is to get it to hook up every time. most L98 cars i've saw don't hook and waste time spinning
read my signature i ran a consistent 14.5 the ither day and rana best of 14.444
1988 firebird formula350tpi msd 6al box blaster 3 coil accel 8.8 wires flowmaster cat back pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges b&m mega console shifter, march underdrive pullies, tpis airfoil
best 1/4 mile run of 14.44@ 96.53
with all the free mods and a tuned car you should hit mid 14s.
1988 GTA Trans Am 350tpi: 42k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, ignition module, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass
Future mods: Edelbrock tes headers, transgo shift kit& corvette servo,1.6 roller rocker arms, flux capasitor(to make time travel possible)
CAR NOT RUNNING AFTER INTAKE INSTALL!!
K&N: filtercharger
What does your car run now? With my 87 (less power and v-belts) with a 2.77:1 rear end, I ran about a 15.0 stock at sea level, so with ur car being newer, with the 3.27s, you should be at least a 14.7. Your best bet after free mods would be a performance tune up, (accel or MSD ignition parts, synthetic oil, rapid fire plugs), then a cat-back and high flow converter, and, if you have an extra $300 or so, a set of TES Headers.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.3 @ 97mph
(corrected for elevation)
L98 TPI 350 (5.7L)
I ran a 14.5 @ 97mph straight off the street....spinning tires terribly off the line....2.6 60' ouch!!!!
goto my webpage to view all my mods....
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and soon to be supercharged
http://maniac.megamania.com
MÅN¡ÅÇ ©
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Tuneup. Headers. Cat-back. A Spohn suspension. TB coolant bypass. Port your plenum. Get a TPIS "fast-pack".
I'm porting plenums for sixty dollars now, as a way to finance my 383 miniram, btw.
See my sig below for my 305's new E/T.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
New best E/T! 14.400 at 98.6 MPH in 88 degree air at Stanton, Michigan.
Daniel Burk
I don't think 14.50's are hard to get for you. Look below for my mods and best time.
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Car: 1989 GTA
Engine: 5.7L
You may be faster than you think; just try taking it to the track first. My very first pass after I bought my car was a 14.59 with no mods whatsoever. I was pleasantly surprised since most magazine road tests were posting times in the low 15's/high 14's.
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
That shouldn't be hard at all. The time in my sig was done with only a K&N and Taylor wires as mods (it was a very cold night though, high 60's). Since then with everything but the headers I've been running consistent 14.4's in Texas heat.
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Black 88 GTA L98
NinjaNife
08-23-2015 11:49 AM
eightsixseven
08-14-2015 03:09 PM
