What fuel pump for carb 383 stroker (former tbi)
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
Hey guys i have a full solid roller 383 stroker (around 450Hp) and my in tank stock pump (92 firebird 305 tbi) has gone out.
What should i replace it with? I have an external holley blue pump, but i guess i need to at least remove the intank pump?
I have a regulator to keep the pressure around 6-7 psi.
Any advice? thanks,
Shane
Any advice? thanks,
Shane
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
removing the old pump isnt nessicary, i've heard of people simply bolting on mechanical pumps when their intake pumps have gone and using the burnt out motor and the fuel pickup
Engine: 357ci Carb
where did everyone mount theirs? any pics?
ive heard to mount as far back as possible, but i dont see any good places. I have a holley blue. (will that be enough)
thanks,
shane
thanks,
shane
Car: 4
Engine: 6
Transmission: 5
I'd get rid of the in-tank pump and just use a mechanical one on the block. A stock one one is entirely enough for that low of a HP level (flow requirement).
Engine: 357ci Carb
how easy/hard is it to install a mechanical one in the block ?
would i want a returnless setup or a return setup?
Some people say you can pull through the intake pump no probs, some say remove it.. anyone done any flow testing? :-/
thanks guys
thanks guys
theshackle
03-05-2017 06:37 PM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
383, 450hp, carburated, carburetor, engine, fuel, mechanical, motor, pressure, psi, pump, size, stock, stroker, tank
