Help me quick!!! Gas is leaking!!!
Car: 86 T/A
Transmission: 700-R4 Auto
Help help help!!! Please!!! When I got home today from school, I noticed a smell. It was GASOLINE!! I looked under the car and saw it was leaking from underneath the hood. So I went under the car and noticed that GASOLINE was leaking out of this cylinder thing that had 3 lines going to it. 2 rubber hoses and 1 steel line. When I would put pressure on the rubber hose, it would leak even more. Please help. Please. I dont know what to do. When I would turn the car off, it would start leaking. When it was running, the leaking stopped. I dont know whats wrong. Please help.
86 Trans Am, 4bbl, 305
fuel delivery leak, if you don't know anything about
cars or carb intakes, TAKE IT TO A MECHANIC.
it's better to have it towed with it off than to drive it
and have it set your few thousand dollar car on fire.
Car: 4
Engine: 6
Transmission: 5
That is the fuel pump.
Extremely easy to replace; 2 bolts and one 5/8" flare nut and 2 rubber lines. Extremely dangerous to ignore: not only is it leaking gasoline to the outside world, but also into the crankcase. You probably have at least 3 quarts more "oil" in it than you think you do, from gasoline leaking into the crankcase.
Change it IMMEDIATELY, if not sooner.
