Got the cam picked out...help me see if it was good choice!
okay, i got part # 08-300-8 from comp cams. its gonna run me around $258.00 i called their tech line and they gave me the specs...here they are below.
206/210
450/480
112 degree lobe seperation
lifter part # 812-16 / $76.00
timing chain part # 2136 / $100.00
spring set part # 983-KIT / $135.00
lots of money that comes out too. like almost $600. hopefully i can get this before august 12th and go run it in the 1/4 mile. u guys think this is to wild or mild? the dude at comp cams said it would work nice with my exhaust. also, if you think i can get these parts for cheaper let me know cause i would love to. im only 16 and im emptying my piggy bank for this one
K&N Air Filter 14x3' Open Element, Edelbrock Catback 3", TES Edelbrock Headers, Gutted Cat, 8.8mm Accel Spark Plugs, Underdrive Pulleys, JET Chip (Thurs of this week)
My 88 RS
206/210
450/480
My 88 RS
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
might wanna upgrade your intake while your at it to get more benifit from your cam
talk to some of the TBI guy about the freebie mods you can do the throttle body etc
I would spring for a new aluminum manifold too since your going to be taking it off anyway..
good luck on the swap
post your results
Jeremy
post your results
Jeremy
Car: 4
Engine: 6
Transmission: 5
262HR: Good choice. That'll work!
It's kind of on the mild side, but it'll still be a major step up from stock. It will idle smooth, cause you no computer trouble, get good gas mileage and all that. You could conceivably go up one step like the one I picked for you but then you might have potential tuning issues. This one should be pretty much a bolt-in and drive proposition.
The lifters in your list are flat tappet. You don't need them. You can re-use the ones you have. That'll save you 76 skins. Other than that, the prices look about right; usually if you check Jeg's, Summit, PAW, and the other mail-order places, and your local speed shop (don't forget, you have to add shipping to mail-order), you'll see quickly who has the best deal.
I think you'll really like it.
k! im so excited will be ordered tommorow! woohoo! how long does a cam swap take? im hoping to get this in before august 12th. and a new intake manifold was gonna be my next mod with a new TBI unit. but for now, im gonna be broke as a joke. i wont order the lifters, thx man
My 88 RS
My 88 RS
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I'm running a 206/206 degree, .500/.500 lift cam at 110 sep. Similar to your selection, with some slight differences. Mine has a little shorter duration than yours, but more lift.
On my TPI system, this cam makes GOBS of torque. Did I say gobs? I meant a whole frikkin' truckload of gobs of torque. I got torque coming out my wazzooo. I can pull stumps with this motor!
Idle quality is fine. Sounds like a ***** cat until you drop the right sneaker.
Only trouble with my cam is that it really starts to run out of steam above 4500 rpm. Part of that is my short duration at .050, and part of that is because of my TPI system. Your cam has slightly longer duration than mine, and I believe that your TBI system won't have such a radical drop off at upper rpm ranges.
Have fun.
p.s.: you will need to have good sticky tires to prevent lighting up the rear end every time you leave a stoplight in front of a cop.
Have fun.
Car: 89 IROC
Engine: Yes
It's a Comp Cams brand. Magnum 260HR to be precise. Mine is a retro-fit roller setup. Roller cam, roller lifters, in a pre-'86 block. The roller lifters allow the radically high lift in such a short duration. The same "260" type cam in a non-roller lifter design would typically have an overall lift of more like .440 to .450 at the valve.
D_Amlee,
I think that 99% of your lack of power above 4500rpm is your TPI. Stock TPI drops off the map after 4500. Your cam's duration is still strong enough to pull up to 6,000rpm. I had a much milder duration cam (194/204) in my last 305 TBI and it pulled up to 6,000 all day long.
Open up that TPI system and watch your rpm's go through the roof!!
And your comment about the GOBS of torque helps me feel better too. I have a 208/214 roller cam in my new 350 and I was getting worried that it won't be up to the task. I was told by a few custom chip makers to stay mild with the duration to keep my TBI setup happy. I really wanted the next step up which is a 214/220 duration. We'll see what happens when I get the new 350 running (very soon).
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
