Block Questions
Block Questions
I have a 74 350 block that i want to stroke and drop in my 87 IROC, WILL THERE be any problems as far has accesories and water pump is concerned, i was talking to a friend and he wasnt sure that it would all bolt up. thanks
Car: '85 Z28
Transmission: WC T5, 3.23 posi
As far as the block goes, everything will bolt up. However if you use different heads than what you have now, they must have the accessory holes in them or everything may not bolt up.
BlackphantomZ28
08-22-2015 01:00 PM
