Car Starting Problem
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
my car will not start at random times.... no pattern of anykind...
engine turns over, gets fuel, gets spark, gets air.... but will not start.... sometimes.... then sometimes it will start up first crank, and run perfect.... then sometimes it will not start.... I have changed the Coil, and Ignition Module, reset the timing, checked the plugs, checked the wires, checked the fuel.... all good.... what else could it be
theshackle
03-05-2017 06:37 PM
db057
08-11-2015 10:11 PM
