Help needed! Re-routing heater core hoses tomorrow morning...
I'm driving a 1985 IROC-Z with a v8 305 TPI, and the heater core went out on me the other day. I don't have the technical expertise to replace the core myself, but I don't have the money to pay someone else to do it right now either. So, I'm going to re-route the hoses. Can anyone be so kind as to post a generic way to go about doing this? Diagrams, pictures, etc., would be appreciated. This is the first major job I'm doing on the car myself. Thanks!
-Anthony Helton
-Anthony Helton
Car: 04 Vette
Just rpute the line from the water pump to the fitting on the intake and that should have you ready to go.
Car: 1986 Firebird
Engine: 2.8 V6
Yep! Just figured I'd add this: Make sure your new "bypass" hose doesn't rest on the exhaust pipes or engine block or fan belts or etc... you don't want it getting cut/melted open.
And changing the heater core isn't technical at all... just a lot of damn screws that are hard to reach from under the dash. You'll need an aspirin or two for your neck after you're done.
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Just connect the two hoses going into the firewall together. I did this when my heater core went bad. Before I connected the hoses together it was leaking, after they were connected leak gone
