Failed NOx emissions
1700 ppm, 1273 is the max. my CO and HC were virtually nonexistant. I've changed the EGR valve and O2 Sensor. I have no codes in the computer. Is it worth it to change the Cat? Its about 5 years old, pepboys el-cheapo and the heatshield is falling off.
1986 2.8 V6.
1986 2.8 V6.
Guest
Posts: n/a
Yes. The Cat was probably clogged by a bad O2 sensor. I replaced my cat a year ago. Within 9 months, my cat passed NOX by only 1 point. So I am swapping it out with a Catco when I install my Hooker Cat Back this weekend. I am also changing the o2 sensor, to prevent premature Cat failure.
Andy
Andy
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
