Speed Ratings
Speed Ratings
I justed bought 2 Kumho Ecsta 712 (cheap), for my rear. They are z rated but my front tires are only s rated. Is this bad? What is the limit for s rated tires? Should I just buy two more, considering they were cheap?
Andy
1987 Iroc
'93 Corvette LT1 350 engine
350 Turbo trans
4" inch Cowl Hood
Adjustable Nitrous Setup(75-175 Hp)
Jet Stage Two Performance Chip
Selling an '85 Sport Coupe
email for details stalemate@pcc.net
Andy
1987 Iroc
350 Turbo trans
4" inch Cowl Hood
you only need to worry about it if you are running over 100mph for an extended period of time......My opinion-I have ran cheap s rated tires up to 130mph or so without problems, But any problem at that speed is bad knews.........Safe bet-Replace them
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
S-rated tires? I wouldn't run 'em unless I had 'em on a VW. Really though. At speeds over 100, I'd be a bit leary. Do you know what happens when a blow-out occurs at speeds in the three digit range? You could end up in the middle of a heap of twisted,flaming sheetmetal.I'm sure the tires are good for doing that speed, but not for extended periods.So, it's all dependant on your driving.
"So,tell me Mr. Stang. How's life like living in the exhaust of a Chevy V-8?"
[Sold] T5 electric speed sensor
Eric-86sc
09-07-2015 02:10 PM
